The paper got stuck while printing, and there is an orange idication
SOURCE: HP Laserjet 1022
on the back side thers are two papers sensors inside the printer,they get stucked,normally they should come back
SOURCE: Prints Photos with an Orange tint.
You may want to try this if you are print from a memory card. Hope this helps. Please remember to rate this information.
Thanks
SOURCE: Cannot Print
After clearing the feed, you usually have to manually tell the printer it is cleared since after a feed it just freezes up and waits for your interference. The easiest way to do this would probably be to just turn the printer off and on again. Otherwise, there will be a button you need to press, usually a paper feed button which will start your print jobs again with out problem.
SOURCE: print cartridge cradle stuck
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
