We have a 7 year old Avaya 18D phone system, and want to change the voice prompts we have on the phone. How do we do this?
Good day Laurel, in order to give more detailed explanation and to help you solve any difficulty; you can download the Avaya Phone System Manual which you can read at your leisure time. hope this works.
SOURCE: Change time
This must be done at extension 10 or 11:
Press Feature and dial zero zero
Press the left intercom button twice
To set the time, press the pound (#) key and dial
103. Enter the correct time using a 24-hour clock (if it's
afternoon, add 12 to the hour...i.e. 3pm
is 1500)
To set the date, press the pound key and dial
101. Enter the correct date using the format MMDDYY (two digit
month, two digit day, two digit year).
Press Feature and dial zero zero to save your changes.
SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
SOURCE: For the Avaya Euro 18D how do you fix the clock?
http://dstech1.com/changing-time-on-a-partner/
Here you go.
SOURCE: partner-18D (lucent avaya phone)on the display it
Get yourself 2 alkaline AA batteries, keep the power on, and look for the door on the lower part of the face on the ACS processor module. Pop the cover and replace the batteries.
Carl
SOURCE: How do I Change Tine on a AVAYA PARTNER 18D Phone?
Press Feature 00 (zero, zero) from station 10 or 11. Press left intercom button twice, press #103, and then enter time in military format (24 hr). Press feature 00 again. This is all done with the handset down.
