The 6-time blink code for the Sony KE-42TS2U indicates a backlight error. This may be due to a faulty backlight inverter board, or a problem with the power supply to the backlight inverter board. It is recommended to have the TV serviced by a qualified technician to diagnose and repair the issue.
Solution
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
Turn off the television.
IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Hi, Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly. Thanks.
Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
Plug the power cord back into the electrical outlet.NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
The 3 blinks (an error code) and the hum (most likely from the flyback) indicate that the flyback transformer is bad and needs to be replaced as the simple way of putting it (fairly common problem with projection tvs). If you plan on doing it yourself, then you should have some electrical expertise since working in a projection tv like this can be very dangerous otherwise I would go through the local shop. Let me know how this turns out for you.
The STANDBY light is flashing on the television and there is no picture or sound.
Solution
