Roper REX4634KQ Electric Dryer Logo
A
Anonymous Posted on Sep 19, 2017
Gas dryer wont stay on
I came home after leaving for a while and had some clother in the dryer - they were still damp but when i closed the door and tried to restart the dryer it would not stay on after I released the toggle switch. I tried holding it on for a few seconds and verified the tumbler was turning but then it started to smoke from the back and I unplugged unit. Any ideas?
Ronald Rissel
Level 3:
Master:
  • Roper Master 715 Answers
  • Posted on Feb 22, 2019
Ronald Rissel
Roper Master
Level 3:
Master:
Answers
715
Questions
Helped
258894
Points
1075
Sounds like you've got a bad motor.
2 Related Answers
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Dec 16, 2008
SOURCE: roper dryer wont work
Disconnect power from unit. The motors centrifugal switch is stuck in the on position. The switch mounts on the motor and when the start button is pushed during normal operation it powers up the motor just long enough to set it in motion. Spring loaded counterweights fly out and apply power to the run windings of the motor. The heater element is also energized as well. If it was me I would tear down the dryer and clean it up. OIl the switch, get it unstuck and retry. To get inside the dryer:you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Take the idler loose and get the drum out. Get a vacuum and clean the moter and inside real good. Oil the switch and get it free. This is not very difficult.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: Roper dryer
Replace the motor, the run winding is shot.It is not hard to replace the motor. The blower has reverse threads(righty loosy). The motor has a quick connect(no wiring needed). Yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way.Get the idler loose and remove the drum. Clean it all up and replace the motor. I can do it in 20 minutes. It is simple and uncomplicated. Go for it.
Cannot get dryer door to close/latch properly.
Hi stay at home MOM
  1. what is the Model of Dryer?
  2. do you pull to open or push button to open DRYER Door?
  3. hinges on the right or the left?
  4. door inner n outer panels plastic?
  5. is there a door seal on the door?
  6. when you did your removal of lint, did you remove DOOR?
  7. picture front of dryer area and door of dryer will help.
Sep 27, 2014 • Dryers
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
1helpful
Series 80 dryer not holding a flame. the flame lasts 1-2 minutes then goes out. IT IS NOT the gas coils because i just replaced them. the thermal fuse gives me a beep from my multimeter. i ordered one
Must be the control thermostat. Note: them coils only stay on a brief period of time. They do not stay on indefinitely. The duration depends on how many wet clothes are in the dryer etc. The least amount of resistance to heat the quicker they shut down. The way it works is temp is maintained between 140f and 105f by doing a series of burns for breif amount of time. The coils do not remain on for very long. If they did the clothes would burn up. You need to remove inspect and clean the filter chute. Probably clogged. The dryer must be put back together for testing with damp clothes in the drum and the door closed.
Door on my frigidaire affinity wont stay close
you are going to have to replace the door catches on the unit in order to keep your door closed
Door on affinity dryer wont stay closed
You will need to replace the door catches on the unit
2answers
The WHIRLPOOL TEDS840PQ0 dryer wont turn on. The
Check the house electrical panel dryer circuit breaker pair--push off, then on. Try the dryer again. If still nothing, measure the voltage across the two slanted slots in the dryer power socket. It should measure: ~230 volts AC. If at or near zero, either one of the breaker pair is defective, or a wire is open from the breaker to the socket. If you read ~230 volts, then the problem is within the dryer--motor runs, but drum doesn't turn (broken belt), or motor doesn't run (bad controller, motor, door switch, start switch. Does the unit get hot? Need more help on your end.
My Amana dryer gets clothes stuck between the drum. how do i fix this
Sounds like the drum bearings are worn out. this leaves a gap for the clothers to stick into. You will need to replace them. Check the support rollers also when you have it apart.
Door does not stay closed
your door clip needs to be replaced or realign
your door
4helpful
Kenmore 80 series Dryer: Door Light stays on and wont start
3helpful
2answers
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
