My icemaker is to make cubes, crushed ice and water, I can get crushed ice and water but not cubes. Can you suggest what the problem might be?
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
