Re: I want to be able to add a yahoo email account
Are you using it online or on a program (ex. Windows Mail). And if you have been using it by a program, have you subscribed to Yahoo! Plus? You can only get POP3 access if you subscribe to Yahoo! Plus. It costs 19.99 a year or a month.
Follow the below mentioned steps :1.
Locate information concerning your particular email service's incoming POP3/IMAP and outgoing SMTP server addresses. Refer to the resources section below for a list of server settings that pertains to many common e-mail providers.nformation mentioned below :
Yahoo Mail offers standard POP3 access for receiving emails incoming through your Yahoo mailbox, by using your favorite email client software. To setup your email client for working with your Yahoo account, you need to select the POP3 protocol and use the following mail server settings:
Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (SSL enabled, port 465)
Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (SSL enabled, port 995)
POP Yahoo! Mail Plus email server settings
Yahoo Plus Incoming Mail Server (POP3) - plus.pop.mail.yahoo.com (SSL enabled, port 995)
Yahoo Plus Outgoing Mail Server (SMTP) - plus.smtp.mail.yahoo.com (SSL enabled, port 465, use authentication)
IMPORTANT : Yahoo mail on outlook or cell phone is a paid service by yahoo.
2.
Turn on your mobile phone and wait for the standby screen to appear. go to "Menu" button on your screen and select "Messages" from the menu, press "Select" to continue.
3.
Go to the "Settings" menu and press "Select," choose the "Email" option. Select the "Email setup wizard," press the "Select" button and hit "Yes" to continue.
4.
Choose an email account type you wish to configure, press "Next," choose the "Account" option, press "Name" and use your keypad to label your new email account.
5.
Press the "Next" button to continue with the email setup. Enter your email address and password, press "OK" to continue.
6.
Enter the incoming POP3/IMAP information pertaining to your particular email service and press "OK" to continue. Select the "Outgoing Server (SMTP" menu item) and enter in the appropriate SMTP address for your email provider and press "OK" to continue.
7.
Hit the "Select" and wait for the "You have configured this email account successfully" dialog to appear.
One problem is that the incoming (POP) mail server shown in the error message appears to be incorrect. The server address should be "pop.att.yahoo.com" (with a period between "att" and "yahoo"). The incorrect mail server address may interfere with authentication of
the sender's email address, which is needed before the outgoing message
is sent.
The "530 authentication" message indicates your outgoing (SMTP) server likely requires "server authentication". Also, the "Port 25" message indicates your email program is currently trying to send via Port 25, with no SSL; but Ameritech/Yahoo accounts appears to use Port 465 with SSL enabled.
I would suggest you check the settings for your Ameritech email account in your email program. You may need to correct several settings. The steps to access account settings are somewhat different for various email programs (Outlook, Windows Live Mail, Thunderbird, etc.). You should be able to find guidance in the "help" section of your email program.
You will need adjust the mail application's POP settings to get your Yahoo! Mail messages into it.
POP access is a service for owners of one of the following:
Yahoo! Mail Pop Access & Forwarding Yahoo! Mail Plus Premium Services
A Broadband account
A Small Business account
Please note that access to IMAP servers is not available.
To use an email client or application to send and receive Yahoo! Mail
messages, you may need to designate a new incoming (POP) mail server and
a new outgoing (SMTP) mail server. Consult your owner's manual for
instructions on designating servers in the email application.
If you can't add new POP or SMTP servers, you will need to change your current server settings.
Before you make any changes, write down your current settings. You might
need to revert to your original settings later if you decide to send
and receive messages from your other email addresses.
The following steps will help you find the POP settings for your Yahoo! Mail account and configure it:
Log onto your Yahoo! Mail account from a PC.
Click Options > Mail Options.
Click POP & Forwarding.
Click Set up or edit POP & Forwarding.
Click POP Settings.
Note your Server Setting information. Your phone email client or application will ask for these settings:
Incoming Mail Server (POP3)- for example, pop.mail.yahoo.com.
Outgoing Mail Server (SMTP)- for example, smtp.mail.yahoo.com.
Account Name/Username, your Yahoo! Member ID- for example, myuserID.
Email address, your Yahoo! Mail address- for example, [email protected].
Password, your Yahoo! Mail password- for example, l0ngitudin*l
Notes:
POP server settings may change from time to time and you should confirm
the current POP server settings in Yahoo! Mail if it is not working.
When using Microsoft Outlook, replace the "@" in your address with "%".
As an alternative to configuring Yahoo! Mail POP mail configurations, go to:
You need to configur your microsoft outlook or windows mail or outlook express in such a way that you recive mails from both the account to one inbox. Follow the below steps if you have ms outlook.
Microsoft Outlook Express Yahoo! Mail users can read their email in Outlook Express by subscribing to the Yahoo! Mail Plus service. This service allows you to use Outlook Express or another POP3 client to access and manage your Yahoo! Mail messages.
Outlook Express allows you to add a new email account to your existing profile. This means you do not have to replace your current settings in order to send and receive Yahoo! Mail messages. Here's how:
1. From the Tools menu, choose "Accounts." 2. Select the "Mail" tab. 3. Click the "Add" button. 4. From the Add menu, click "Mail." 5. In the text box labeled Display Name, type your name and click "Next." 6. In the Email Address box, type your Yahoo! Mail address (be sure to include "@yahoo.com") and click "Next." 7. Under "My incoming mail server is a..." select "POP3." 8. Type "pop.mail.yahoo.com" in the Incoming Mail (POP3, IMAP, or HTTP) Server box. 9. Type "smtp.mail.yahoo.com" in the Outgoing Mail (SMTP) Server box. 10. Click "Next." 11. In the Account Name box, type your Yahoo! Mail ID (your email address without the "@yahoo.com"). 12. In the Password box, type your Yahoo! Mail password. 13. If you want Outlook Express to remember your password, check the "Remember password" box. 14. Do not check the boxes labeled "Log on using Secure..." 15. Click "Next." 16. Click "Finish."
Important: The Yahoo! Mail SMTP server now requires authentication. To turn this setting on:
1. From the Tools menu, choose "Accounts." 2. Select the "Mail" tab. 3. Double-click the account labeled "pop.mail.yahoo.com." 4. Select the "Servers" tab. 5. Check the box next to "My Server Requires Authentication." 6. Click "OK."
To control deletion of messages from the Yahoo! Mail Server:
1. From the Tools menu, choose "Accounts." 2. Select the "Mail" tab. 3. Double-click the account labeled "pop.mail.yahoo.com." 4. Select the "Advanced" tab. 5. In the Delivery section at the bottom of the window, check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Do not check this box if you want your messages to be deleted from the Yahoo! Mail server once you have received them in Outlook Express.
If your ISP blocks port 25 or if you're unable to send email, then you will need to use port 587 when sending via Yahoo!'s SMTP server. To make this change, please follow the directions below:
1. From the "Tools" menu, select "Accounts" 2. Select your Yahoo! POP account and click on the "Properties" button 3. Click on the "Advanced" tab 4. Next to "Outgoing server (SMTP), change port 25 to 587 5. Click "Apply", then click "OK" and "Close"
If you have Yahoo! Mail Plus (a paid upgrade), you can access those messages directly from a standard email program (such as Outlook, Windows Live Mail, etc.). You need to configure the account settings in your email program for the Yahoo service.
The settings for incoming mail are: Incoming (POP) server: plus.pop.mail.yahoo.com Port: 995 Security: SSL
You must allow your router access to send out mail. other wise it will keep the messages you send in the outbox. go to your router setup or type your router ip address in the internet browser and manually enable the port 465 you may have to goto applications and games tab if you have a linksys router. Also enable ports 80 for internet,25 for simplemail transport protocol (SMTP),110(e-mail),443secure (bank account information) this will allow the router the proper ablity to send and recieve e-mails.
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
yahoo's UK page has instructions on this and here they are: id rather paste theirs than type my own...
In the text box labelled Display Name, type your name and click "Next."
Under "My incoming mail server is a…" select "POP3."
Type "pop.mail.yahoo.co.uk" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
Type "smtp.mail.yahoo.co.uk" in the Outgoing Mail (SMTP) Server box.
Click "Next."
Do not check the boxes labelled "Log on using Secure…"
Click "Next."
Click "Finish."
Double-click the account labelled "pop.mail.yahoo.co.uk."
Click "OK."
To control deletion of messages from the Yahoo! Mail server:
If you'd like to keep a
copy of your email messages on the Yahoo! Mail server, check the box
next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook Express, don't check the box.
If you're unable to send email, try using port 587 when sending via Yahoo!'s SMTP server. Here's how to make this change:
From the "Tools" menu, select "Accounts."
Select your Yahoo! POP account and click the "Properties" button.
Click the "Advanced" tab.
Next to "Outgoing server (SMTP"), change port 25 to 587.
