I can not find an HDMI port on this tv. I was wondering if there even is one.
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr
I have lost my manual for the lct27ta. Have you gone into the menu and setup the hdmi port?
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
SOURCE: is there a hdmi port on this tv akai lct2662
No there is not. But it does have a two component and one VGA imput.
SOURCE: AKAI 27"LCD SN:60683669 Have HDMI connect o
Universal remote controls (like the one for your comcast cable box in which it allows you to control other devices) have "the most popular" IR codes programmed inside of it. When you type in the numbers "10812,10702, etc" you are telling the remote to use that particular IR code within its "database"
The key thing to know is that universal remotes do not have every code, just the most popular. If you have tried all of the codes listed in the manual for you model TV there's not much you can do.
I hope this helps.
