SOURCE: H98 code on a panasonic microwave
Go back to the manual, and read the whole thing or just look at the Chapters names, and find teh right one, and hopefully that will answer your problems.
I am a myth, a myth surround by spirit and souls.
- Myth12 [ i love blogs]!
SOURCE: Error Code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
SOURCE: ERROR CODE H98 ON MY PANASONIC MICROWAVE OVEN.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US or Canada, see Panasonic.net.
SOURCE: H98 ERROR CODE ON A
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
SOURCE: our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Testimonial: "We had to go out and get a new one, basically H98 means that it was "fried"...learned lesson to try and keep all appliance manuals organized on file...we couldnt find ours so it was nice to try on-line....thanks for the help"
This oven is
programmed with a self diagnostics failure code system which will
help for troubleshooting, H97, H98 and H99 are the provided failure
magnetron and inverter circuit problem areas. This section explains
failure codes of H97, H98 and H99. H97, H98 and H99 appears in
display window a short time after start key is pressed and there is
no microwave oscillation.
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
