SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
SOURCE: Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
SOURCE: I have a Frigidaire FRS23H5ASB9 side-by-side. The
most likely the solinoid is frozen or bad.. pull ice bin, the metal lever on back of bin fits in solinoid in freezer see if you can move plastic piece in freezer with finger.
SOURCE: Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
SOURCE: Frigidaire Gallery Professional Series -
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
I appreciate your post, friend!
I understand that your icemaker is dispensing ice cubes at a slow pace inside of your Frigidaire refrigerator. You could have a slow ice production due to your water filter or water valve. I would suggest checking to make sure your house supply is fully opened and check to make sure your filter does not need to be replaced. This could also be an issue with your water valve. Since it could be anyone of these underlying issues I would recommend contacting a professional technician for proper diagnosis and repair. This will also help you to avoid any unnecessary part purchases. -Matt
