I cannot even format again old discs previously formatted wif this same player which had old programs recordedI cannot even format again old discs previously formatted wif this same player which had old programs recorded
You can't post conmments that contain an email address.
Eject the DVD from the Cyberhome DVD player. Look over the bottom of the disc. If any dirt and fingerprints are present, remove them with a damp cloth, moving from the inner circle of the DVD to the outside.
Insert the DVD into a scratch repair device, if the DVD has any light scratches (deep scratches are not reparable). Turn on the DVD repair kit and the device literally sands down the scratch. When this is finished, the DVD should work correctly with the Cyberhome DVD player.
Avoid inserting homemade DVDs into the disc drive. The Cyberhome is not compatible with many self-created DVDs, causing a "Disc Read Error" message to appear on the screen.
Spray compressed air into the disc drive of the DVD player. The compressed air removes dust and other debris from the laser and reading lens in the player.
try playing a disc that you know it has played before. if it does play other dvds then your problen is that it cant read the format in wic dat specific disc u are inserting in there. if it doesnt ready any dvds then insert a music disc in there, if it does play it then u got to change the lens. there is also the possibility then the motor spinning the disc might have gone bad as well so when changing the lens, it is advisable to change the whole lens mechanism.
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
There are several things you can do to try and solve your problem:
Make sure that the DVDs you try to play are encoded for the right region.
Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged.
Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
bought used dvd player when i insert turn on screen doesnt light up
