I don't have the tool to access the sparkplug
SOURCE: buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
SOURCE: I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
SOURCE: 4000 watt buffalo tools generator: Engine
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
SOURCE: I need a gas tank
call buffalo tool parts dept.they have brand new tanks for $36.75 or if you need a petcock they cost $9.95 they also have the gas gauge for $9.60.call 1-800-568-6657
