Istalling water actuator, part #241685704 for frigidaire refrigerator, model #phsc39ehss0
Getting access to the actuator. this is the procedure;
turn off the power
Remove the drain tray it just snaps out. remove the 3 screws behind the tray. carefully lift the panel up and out. There is a short control wire connecting the panel to the frig so be careful. remove the water hose from the outlet hole and remove the ice and water module.
its very easy
The drip tray will just slide out and then you will see the screws that hold the trim in place.
to get more complete details just click the link directly and get the proper diagrams
http://appliancejunk.com/forums/index.php?topic=282.0
if you have not had the fridge repair yet here is how to get in to the dispenser to get the actuator.
Feel or look along the bottom edge of the trim on the dispenser and you will see two slots.
Use a flat blade screwdriver to pry the bottom off.
Then slide the trim up and lift it off this will give you access to the screws to replace the actuator.
Here is a place to get Frigidaire parts
please do rate the solution.thank you for using fixya.keep updated.thanks.
