Treadmill stopped with elevation stuck at the highest elevation. Will not stay on. shuts off as soon as it starts and displays Code E5
SOURCE: no start no stop of my teadmill t9600 but the other buttons areok
The buttons on this unit are on an overlay. Basically, the buttons are a big sticker that goes on the console. I would start by checking the connection between the overlay and the console board. If the connections in good, then try a new overlay. If that does not work then the console board is bad.
Testimonial: "It was the connection between the overlay and the console board. It was disconnected. Thank you very much !!! Marc"
these are the most often used functions you just worn them out you can call vision fitness they will ask the upper console model and serial # (located on the back end of the console ) Here is their # 1-800-335-4348
SOURCE: I have a vision T9500
hi, With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START. (The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen) If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module. OK
Try AUTO-CALIBRATION first. For that do the following.
