Question about LG WD-1280FHD Front Load Washer
I can't get water in the LG 1460FD - LG WD-1280FHD Front Load Washer
    New Friend:
  • 66 Answers
With the inlet valve filter may be block..
Posted on Feb 22, 2014
2 Suggested Answers
6ya staff
SOURCE:
fcalvell
  • 9 Answers
SOURCE: LG wd 1460FD is not loading water
Try this.
reset machine. start a quick cycle. Once the pump starts, open door and add 2-4 cups of water. close door.
If machine starts to work the the water inlet valve needs to be replace.
Posted on Jan 06, 2014
New LG LFXS30766S refrig. Water disp.not putting out full stream of water despite doing what the manual said to do. Old Maytag refrig. I had put full stream of water with no problem.Any suggestions?
LG refrigerators are notorious for junk water valves. IF you have replaced the filter, then your next item is to replaced the water valve. AJU72992603
Jun 22, 2016 | LG Refrigerators
Lg refrigerator not dispensing water valve in door leaking when prees button
Seals in water valve are likely leaking. Disassemble rebuild or replace water valve .
www.lg.com/us/support/refrigerators
www.lg.com/us/support/parts-accessories
Jun 06, 2015 | LG Refrigerators
LG side by side model# lsc26905tt, won't dispense water. I can hear the pump trying to pull water but the water is sitting in water line just outside of filter on the outside of fridge.
Sounds like the dual solenoid water control vave. Located in the back it will have two wire connectors going to solenoids. They are replaced as a pair and most local appliance dealers have universal replacemants. http://www.lg.com/us/refrigerators/lg-LSC26905TT-side-by-side-refrigerator
May 31, 2015 | LG Refrigerators
Try this.
Jan 06, 2014 | LG WD-1280FHD Front Load Washer
Wd-1460fd is not loading water
check the water inlet valve.
http://www.youtube.com/watch?v=i5nygF7meKQ
Water leak from dispenser
The reservoir inside has to be replaced. After numerous calls to LG, I finally got the LG Mobile Service Tech to service it, and the water reservoir has been completely redesigned....can you say "design flaw?" Now, since the new "tube" has replaced the "reservoir," I have little green things floating in my filtered water! I hate LG products.
Dec 11, 2007 | LG LRFD25850 French Door Refrigerator
LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Jul 31, 2007 | LG LRSC26980 Refrigerator
LG WD-1280FHD Front Load Washer Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
