Question about LG WD-1280FHD Front Load Washer
LG wd 1460FD is not loading water - LG WD-1280FHD Front Load Washer
    New Friend:
  • 9 Answers
Try this.
reset machine. start a quick cycle. Once the pump starts, open door and add 2-4 cups of water. close door.
If machine starts to work the the water inlet valve needs to be replace.
Posted on Jan 06, 2014
6ya staff
SOURCE:
LG front load machine won't fill when cold water selected, still uses hot water
Some hot water is admitted on the cold cycle to dissolve detergent (especially powdered).
Dec 27, 2016 | LG Washing Machines
Wd-1460fd is not loading water
check the water inlet valve.
http://www.youtube.com/watch?v=i5nygF7meKQ
Jan 06, 2014 | LG WD-1280FHD Front Load Washer
I can't get water in the LG 1460FD
with the inlet valve filter may be block..
I have a LG WD 1238C Front Loader Washing Machine and the display has a CL on it.
Remove power for some time , allow the power to drain off the memory and see if the display is clear. If not hold the start button and switch on power. Check the inlet and drain filter , free water flow, if not remove and clean.
Nov 01, 2013 | LG WD-1280FHD Front Load Washer
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
My Lg WD-3274RHD after a load is complete It fills with water again? If left ovder night water will run out the door.
I have same problem with my washer/dryer combo.It took me quite some time to figure out what is going on.Did all electrical checks ,everything was fine and worst thing it was intermittent thing ,it would do it 8 out of 10 times. Found cold water inlet valve assembly to be faulty (mechanical problem with middle valve) . Second time in 6 years ,other than that I'm very happy with that combo.Problem now is to get new valve, because it is not available anymore from LG, so I'm digging through internet to see if anybody has it somewhere. Good luck
May 06, 2010 | LG WD-3274RHD Front Load Washer / Dryer
Water leaking after i have installed a new drain pump in LG
Obviously you need to find the leak and repair it...duh
Mar 12, 2009 | LG WD-1280FHD Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WD-1280FHD Front Load Washer Logo
168 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
