SOURCE: Our Sony Blu-Ray BDP-S300 will play older Blu Ray
Try to update the firmware on the player by going to this website http://www.blu-ray.com/firmware/firmware.php?id=10 the newest version is 5.20 fixes alot of problems including playback issues with some BD movies and safe the file into a flash drive and plug it in on the back USB port, go to menu/firmware update run the update.
SOURCE: how do you update a sony blu ray player bdp-s300?
You can Update the Firmware of the Blu-ray Disc Player(BD Player) in two ways.
1. By downloading Firmware update and burning it to a CD-R disc if you have CD Burner in your Computer.
a)Download the Firmware update from Sony website for free to your Computer and then burn it to a CD-R disc by following the instruction mentioned on the download page.
b) Insert the burnt disc into the BD Player and follow the on-screen instructions to install the Update.
Please click on the link and select the correct Operating System installed in the Computer to which you are going to download and burn the Update. Then, click on Download icon to download the Update.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300&SelectOS=27
The detailed instructions are mentioned on the page.
2. Second, if you do not have a CD Burner in the Computer or you do not wish to download and burn the Update, then you can contact the Sony Customer support to order a FREE UPDATE DISC. They will ship the disc to you free of cost.
SOURCE: unlock sony blu-ray bdp-s370 player
Turn on the BD player. Press and hold the PLAY button and the STOP button until UNLOCKED appears on the front panel display.
SOURCE: My Sony Blu ray player
I suggest that you install the latest firmware update to resolve the issue. Please click the following link to download the latest firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6170&mdl=BDPS300
It is recommended to use CD -R disc to create the firmware update disc.
I hope you're clear with downloading the update from support page.
Once you download and save the file in the folder in the computer, you can double click the file to extract.
You will be prompted to save the UPDATE_BDPS300_VER0550.ISO file in a folder.
Most of the customers will be making mistake here after...
We need to use a burning software which is capable to burning discs from ISO images. ISO image is nothing but a RAW format of burned image.
I will give you the instructions to burn using Nero.. Steps will be almost same in all ISO capable software.
Open installed nero software from computer. You may locate it under Start Menu programs.
Go to File Menu (Some times you will get a wizard where you can select the Image Burning option or burn ISO option)
Navigate the extracted .ISO file we saved in the computer.
follow the onscreen instructions.
Insert the disc when ever Nero asked to insert
Hope this helps. If you need any assistance. Please get back to me. I will be more than happy to assist you. Thanks for understanding.
SOURCE: Sony BDP-BX2 blu-ray disk player "SYS ERR" error message
This worked for me, from a Sony Tech.
1) When SYS ERR is displayed turn off the player by holding down the power button until tghe unit turns off. 2) Unplug the power cord. 3) Wait a minute or so and plug the player back in. This reset the player for me.
