Paper feed stops about halfway. The printer reports paper jam. I check this out and it all looks OK.
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: Photo Paper Jams
Based on your question, my first thought is that you changed the type of photo paper you used starting "this week" (when you first posted your question). If you did, the photo paper size/thickness may not be compatible with your printer.
Otherwise, there may be a problem with the paper sensor. Click on the following link and review the troubleshooting steps, particularly Step 2, to see if that helps:
Paper Jam Troubleshooting
Post back your results. If you are still having the problem, post any additional information you think might help solve the problem. Thanks and good luck.
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
