Sewing Machines Logo
A
Anonymous Posted on Aug 31, 2017
Skipped stitches I have a pfaff 2040 and am having problems with the stitches skipping. Some fabrics, flannels, do better than others, less expensive cottons. While doing a straight stitch or blanket stitch I can't get the top thread to connect with the bottom and lock. Any suggestions? I have re threaded, changed thread spools, cleaned dust from the bobbin area, and oiled. Please help!!
R.A. Ellis
Level 3:
  • PfaFF Master 12,731 Answers
  • Posted on Sep 03, 2017
R.A. Ellis
PfaFF Master
Level 3:
Answers
12731
Questions
Helped
2619131
Points
59176
Always try a brand new needle first--a dull or bent needle will skip stitches. AVOID old or bargain bin threads! Be sure to use needles that are compatible with the thread and fabric you are sewing. Using the wrong type of needle will frequently cause skipped stitches, ie ball point needle on woven fabric. If you have exhausted all your ideas, it could be possible the machine is somewhat out of time.
Basic Maintenance Tension Skipped Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
10 reasons for skipped stitches
Schmetz Needles Needle Guide
Sharron Krieger
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 156 Answers
  • Posted on Sep 02, 2017
Sharron Krieger
Expert
Level 2:
New Friend:
Cheetah:
Answers
156
Questions
Helped
28927
Points
282
Lower your needle. If up to high can't catch the bobbin thread.
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Aug 09, 2008
SOURCE: pfaff 7570 bobbin tension
Check this link, it is threading diagrams, hope it can help you.
Anonymous
  • Posted on Dec 30, 2008
SOURCE: thread shreds with Pfaff
I have the book on that machine as well and I have had that problem. Here is what had happened to me: I was soooooo tired of that shreading thing that I took a flashlight and aimed it up the nose of the machine by the lightbulb and fould there to be a nice little rats nest wrapped around the take-up lever and the needle bar. I spent the next three hours getting to that nest with the skinniest and longest tools I could find. Oh it is was fun!
Mimito7
Kelley Buchanan
  • 130 Answers
  • Posted on Apr 25, 2009
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
sylviaivie
  • 1564 Answers
  • Posted on Mar 12, 2011
SOURCE: I inherited my mother's Tiptronic
Deep breath. Ohmmmmm.... ok now.
Few things you need to know.
1. Try to remember TTN when you run into problems like this it stands for Thread, Tension, Needle. Contrary to popular belief, there is no such thing as universal thread and needles. You'll need to determine what kind of thread and needle is best for your application.
2. When things gets bunched up under the fabric it Usually means that the tension for the top thread is too loose. However, a bad, bend or just plain wrong needle will cause these problems too.
3. Always grasp the threads (both top and bottom) and pull gently backwards when starting a seam. Some old school seamstresses and seamsters say to make sure your needle is at its upper most position (just before it starts to move down) before you begin sewing.
4. since you've had a couple instances with this issue... you might have to clean the bobbin race area. I'm a bit reluctant to tell you about this but remove the bobbin and look carefully for other stray threads, dust bunny's etc.
I hope this helps some. ;o)
S
raj somaiya
  • 5370 Answers
  • Posted on May 16, 2011
SOURCE: I have sewn on my
Bobbin thread being too loose is due to two possible factors. The upper thread may be too loose allowing the bobbin thread to pull it under the fabric, or the upper thread may be too tight in which the bobbin thread will pull up to the top. Try adjusting the top tension to see if you can correct it. If it doesn't fix the problem, take out the bobbin and look for a screw on the bobbin case. If your bobbin case comes out from the underside of your machine, the screw is on the side. If yours is a drop in bobbin, it will usually be under the faceplate so you might have to take that off too to get to it. Turn the screw clockwise to tighten the bobbin, counterclockwise to loosen it. Only go a quarter of a turn at a time so you won't overshoot the mark.Then try by re-threading and sewing. The basic procedure for threading is as follows:---------- Note that Pfaff sewing machines thread from left to right, not right to left like other sewing machines. The upper tension discs should be raised at their highest position while threading, and the presser foot should be raised up until you thread the needle. Drop the presser foot right before you thread the needle. The prevents thread problems during use.-------------
  • Insert a full bobbin and retrieve the bobbin thread through the thread plate. Raise your sewing foot and needle to its highest position; hold the needle thread taught with your left hand, lower the needle into the thread plate using your right hand, and then raise the needle. As you raise the needle, the needle thread will catch the bobbin thread, and pull it up. There should be a loop of thread intertwined with the needle thread. Use tweezers, your finger, or a straight pin to retrieve the bobbin thread that is visible through the thread plate, and pull it through the plate.Place the fabric under the presser foot, and drop the presser foot. Choose the stitch you want to use from the top stitch display, right above the top thread feed. Press the '0-9" button located on the sewing machine's front panel, and a display screen will come up. Input the thread number, and press the 'OK' button located on the sewing machine's front panel.-----------this is procedure.
    If problem persists.Remove bobbin and clean lint from bobbin and re-tight the bobbin properly, then check.This should help.Thanks.Helpmech.
  • Ad
    1helpful
    Industrial sewing machine jumps a stitch passing from thich to thin layers (from a double layer to a single) any help?
    When sewing from thick to thin layers, it is common for industrial sewing machines to skip stitches or produce uneven stitches. Here are some things you can try to prevent this issue:
    1. Use the right needle: A needle that is too small or too large for the fabric can cause skipped stitches. Make sure you are using the correct needle size and type for the fabric you are working with.
    2. Adjust the presser foot pressure: The pressure of the presser foot can be adjusted on most industrial sewing machines. Decrease the pressure of the presser foot when sewing over thinner layers to help prevent skipped stitches.
    3. Use a walking foot: A walking foot can help prevent skipped stitches when sewing over multiple layers of fabric. The walking foot will help feed the fabric through the machine evenly, preventing skipped stitches.
    4. Adjust the tension: If the tension is too loose or too tight, it can cause skipped stitches. Adjust the tension according to the fabric you are working with.
    5. Use a stabilizer: When sewing over thin fabrics, use a stabilizer to prevent the fabric from puckering and causing skipped stitches.
    If none of these solutions work, you may need to take the machine to a professional for further inspection and adjustment.
    1helpful
    2answers
    What is the rght tension for The Elna Contessa 410 sewing machine?
    Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
    Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
    Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
    What to Do If Your Sewing Machine Is Skipping Stitches
    My pfaff hobbymatic 875 is skipping thread on the bobbin side
    Be sure to use a brand new needle. If the needle is bent or damaged, it will frequently skip stitches. Also, if you are using the incorrect needle for the fabric & thread you are using, it will skip stitches, ie a ball point needle on woven fabric.
    All About Needles
    Open-toe darning foot skips all stitches....help!
    Hmm, have you installed a brand new needle? Make sure the needle is compatible with the thread and fabric. Sometimes a top stitch or microtex needle will work better for free motion quilting or darning.
    https://www.superiorthreads.com/education/what-causes-skipped-stitches
    https://moonlightingquilts.wordpress.com/2012/04/19/skipping-the-skipped-stitches-in-your-free-motion-quilting/
    https://www.generations-quilt-patterns.com/skipped-stitches-driving-you-nuts1.html
    1helpful
    Can lint get up inside the shaft that raises and lowers the needle?
    the needle bar is not hollow,
    Skipped stitches
    1. The needle is not inserted correctly
    Remove needle & reinsert needle( flat side towards the back of machine)
    2. The needle is damaged
    replace with new needle
    3. The wrong size needle is being used
    Choose a needle to suit the thread & fabric
    4. The foot not attached correctly
    Check & attach correctly
    1helpful
    2answers
    Skipped stitches
    Try some Schmetz brand needles, they skip less than any other brand. If that does not solve the problem, you need to have it serviced.
    3helpful
    Pfaff 1222E machine not working right
    Skipped stitches means a bent or dull needle or improper needle for the fabric being sewn. Try a new needle of the correct type for the material being sewn. If this doesnt correct it, then it will be a timing or needle to hook problem and should go to a qualifed dealer for repair.
    2answers
    Free motion quilting skipped stitches, breaking threads
    Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
    Top PfaFF Sewing Machines Experts
    ExpressFiX
    ExpressFiX
    Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
