Question about LG 42PX5D 42 in. Plasma HDTV
Buzzing from back of tv when turned off
I have a 42px5d model which i have had for about 15 months. it makes a buzzing noise from the rear when it is turned off. it sounds like a bee buzzing and it comes in waves. i first heard it a few weeks back and then again today..any solutions??
    Champion:
  • 317 Answers
Call tech ...suggest cleaning fan
Posted on Nov 26, 2007
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I have a SAMSUNG HLP5674W and it has begun to make a Loud buzzing/humming noise from the rear of the tv... It sort of sounds like a fan and when i listen closely, that area is exactly where the noise is...
pull the light assembly out clean it with a vacuum and some pressurized air spray and place it back in the TV, while it is out check the fans on either the inside or in the removable assembly for damage or other interference in operation...If this doent help dissemble/remove the rear of the enclosure ( 6-10 screws) and clean the insides carefully and then turn the tv on - being careful not to be touching ANYthing and see if you locate the culprit.....
Oct 24, 2013 | Samsung HCM5525W 55" Rear Projection...
I have the samsung DLP HL-6163W model. I've had this TV for 6 year, and have logged many hours on it. Tonight, the TV started making a buzzing noise in the back, and the colors got all screwed up. I...
This tv have a colors wheel design in it to this tv.The buzzing noises and the colors are all screwed up because the colors wheel is worn out and spinning off of is axis and rubbing it against the wall of it hall of the steal box frame that hold the colors wheel itself.Don't attemp change the colors wheel by ur self,if u have no mechanical skills.Bacause the colors wheel itself sit way back of the tv,have to take out many mechanicals parts,before can come to the colors wheel itself to replace it.Because u will regret it later if u putting the colors wheel itself in wrong.Hire a tv repair person to replace it.
Apr 04, 2011 | Samsung HLP6163W 61" Rear Projection...
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
Mar 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My SOny Projection HDTV makes buzzing noise when turned on
if tv is a dlp you have eithor a bad color wheel or bad fan.would need model number to research it more
Sep 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Constant humming/buzzing noise
I purchased a poloroid tv 3732 in may of 2005 from circuit city, after about 14 months the set began making a clacking sound and humming sound that gets so loud it is unbareable. I have to turn the set off. I have found out I am not the only one with this problem that has a poloroid tv. I had a technician at my home that told me there is a service warranty on these sets because the wrong part was used and the part needs to be replaced.
Oct 29, 2007 | Polaroid FLM-3732 Television
LG 42PX5D 42 in. Plasma HDTV Logo
202 people viewed this question
Ekse
RONALD CARTER JR
