Question about Fisher and Paykel GWL11 Top Load Washer
Smart drive 708 washing machine only partly fills with water then stops
The machine starts to fill up with water but stops at a certain point and wont start because it doesnt have enough water, when you top up the water manually it will then start to work.
    Master:
  • Fisher and P... Master
  • 745 Answers
Probably a faulty cold water solenoid
Posted on Apr 21, 2018
  • wenzt123 Sep 22, 2018
    or blocked filter in valve or at tap
6ya staff
SOURCE:
Anonymous
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Posted on Jan 11, 2008
prem mathew
  • 1294 Answers
SOURCE: F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Posted on Feb 08, 2008
Anonymous
  • 3 Answers
SOURCE: wont wash
Remove lid then control panel. Unhook all terminals, remove control board, then second "box" which is further away towards back of machine. Sensor is 'back/right," under this second box. Unhook connectors & remove wee sensor carefully. On the side of the sensor is a tiny plastic button the size of a pen top. This should move in & out freely. It is spring loaded. If it sticks replace it. Good luck on your mission.
Posted on Jun 08, 2008
SOURCE: washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
Posted on May 29, 2010
Anonymous
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Machine wont fill with hot water
problem in hot water tap
hot water solenoid not activating to let water in
to prove either switch the hoses on the taps and press cold water wash
that proves the tap
then press hot wash and that proves the solenoid
Jul 21, 2016 | Fisher and Paykel Washing Machines
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
The smart drive 708 on any wash cycles has poor water flow..ie the water seems to be filling up very slowly and the normal wash cycle takes 2hrs
Hi Challe340, Sounds like your machines Inlet solinoid valve that supplys water to your machine may have a clogged internal diaphagm, its quite normal for it to clogg up due to high sediment build up in the water mains over the years and seeing that the machine is a smart drive 708 it probly hasnt had inlet replacement in it entire life. As for the normal wash cycle taking so long could be due to restriction in water flow from the faulty inlet valve slowing down the water fill segments in its rinsing cycle stage, hope this help.
May 01, 2011 | Washing Machines
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Machine wont fill
If you hear a valve or relay opening and closing (a small click), then check both of your hoses for signs of internal collapse and while they are off, clean the screens you may find in both ends.
If you see nothing amiss, open both of your feed faucets to make sure it is not a problem with the water supply itself.
Jun 18, 2008 | LG WFT1071TP Top Load Washer
Fisher & paykel slow to fill?
if its the cold water (most common) replace the valve remove the two screws on the top of the control panel then you will see the valve i think its the right one looking from the front.its an easy job .hope this helps.
Mar 20, 2008 | Washing Machines
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Open Questions:
See all Fisher and Paykel GWL11 Top Load Washer Questions
Fisher and Paykel GWL11 Top Load Washer Logo
136 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
