Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Logo
A
Anonymous Posted on Jan 06, 2014
FFLE1011MW washer won't start. Checked breakers, reset electric plug, still won't start
WASHER WON'T START
Thank you for your inquiry, friend!
I see that you are having trouble with your Frigidaire washer not starting. This sounds like a possible problem with your control panel or keypad. You may need to disassemble the washer in order to pinpoint the possible problem this is not a simple DIY job. I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid future issues as well as possible multiple part purchases. I hope this information is helpful. -Matt
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
When you push start button nothing happens
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Pump won't run
Did you figure this out yet? If not.
Did you check the onboard GFI breaker switch?
Did you make sure the water was connected and turned on?
I was doing a small load of laundry when the breaker tripped
Sounds like an electrical short somewhere in the washer. Needs to be checked out by qualified service tech.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
