Where is the thermal fuse located on a Kenmore dryer model 110.67032600? I've been told it's on the exhaust duct but I don't see it. Thanks.
SOURCE: kenmore model 96284100 dryer
The thermal fuse should be connected to and near the heating element. Check the paper electrical diagram, taped on the inside of the dryer.
InMrFixIt
SOURCE: thermal fuse
HI sorry the thermal fuse is located on the air duct, on the left a small plastec piece with 2 blue wires to it , the hi- limit is located on, the heater box.
SOURCE: how do i test a thermal fuse
A fuse is tested using the continuity or resistance (ohm) setting on a multimeter.
Disconnect the power to the dryer. Disconnect the leads to the fuse. With the meter set on continuity, the meter should beep - if you set to ohms, you should read 0 ohms across the terminals of the fuse. If you read infinity, the fuse is bad.
SOURCE: WHERE IS THE THERMAL FUSE LOCATED ON MY KENMORE GAS DRYER?
It should be on the flame tube , small round part with 2 wires , it may be hiding toward the back of the tube or built on a bracket close by it.
Phil
SOURCE: On the Kenmore series 90 electric dryer, where is
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
