I have owned my NAD 7140 for forever, it's been a great little receiver but the Station Preset memory tends to lose the saved stations from time to time. The power cord is never unplugged and it works fine otherwise.
How does one fix this? Is there a battery inside that needs replacement or a capacitor that holds the station memory alive? I have some skills with electronics and can use a DVM etc but so far have never bothered to open the case to explore, as we just reset the station memory and keep on listening!
Thanks,
Lazy Glen
SOURCE: would like to know year
Hi - You can download the manual by clicking the link underlined in blue below:
Nad 7140
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: NAD 7140
Hi okapi6
Use a 3.5mm stereo jack to RCA connector lead.
Connect this to the AUX input on the back of the 7140, and away you go. Get the lead as an accessory from just about any electronics hobby store.
SOURCE: NAD 7140
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
SOURCE: will NAD 712 accept an iPod Docking Station?
A 712 is not set up to use an Ipod USB dock. You can buy a dock that will use RCA jacks into an old stereo - Apple sells them, others too. Then the Ipod sits up and you can look at it. Or you can buy the 1/8" stereo plug to two RCA plugs that Radio Shack has been selling for 30-40 years, plug one end into your Ipod headphone jack, and run the two RCA plugs into your Aux input. That costs about $5, and is easy as pie. An Ipod will play through any old receiver, but the USB docks will not plug into them.
SOURCE: NAD 7130 FM stereo signal (on off again and again)
The contacts in the A B speaker selector switch had degraded on my NAD 7130 receiver. Distortion and signal loss would come and go. Contact cleaner and wriggling the swx knob became useless. Then, years ago I jumped the swx with small lengths of bare wire and tinned the whole thing with solder. Never had a problem since and it probably improved the receiver because it eliminated a component in the output stage that could (and did) introduce distortion.
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
• A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
• If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
• Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
