Side by Side kitchenaid fridge. For 24+ hours the freezer side has been holding steady at about 30 degrees F, fridge side at about 46 degrees F. Neither side cold enough to do its intended job, both set on coldest setting. Temps were higher until I cleaned the coils. Any ideas for what to do to get the temps down a little more? Thanks in advance.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
Is the refrig running constantly? and still can't get to 0deg???
You say it's 30deg in there! I assume you are using a thermometer IN the freezer. Is the fan in there running (you can hear it). If it is, and you say you aren't cold enough, you lost freon...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
