The condenser in the outside unit turns on however the fan does not start without a push and then it rotates at slower than normal speed. The condenser cuts off after a few minutes I assume because it heats up. The air seems to be cooling for the first few minutes before the condenser shuts off
SOURCE: lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
SOURCE: LG LWHD 1200 HR Air/Heater fan will not start.
may be a bad fan motor or loose wire, however some units have dip switch settings on the circuit board preventing the fan from coming on.
SOURCE: HEAT PUMP/AIR CONDITIONER UNIT SMELLS ONLY WHEN AIR IS ON
Not sure what the smell...smells like. My guess is dirt or dust near the heating elements. These will cause a burning smell. Sometimes insects even get into the act..building webs.
You will have to clean that area out...sometimes a large blower or vac can dislodge the dust.
SOURCE: LG air conditioner 24awn error code message Ch 6
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
SOURCE: air conditioner shuts off
C5 • Wrong or missing wiring between indoor and outdoor unit cable • Defect of communication components in indoor pcb assembly • Defect of communication components in outdoor pcb assembly • Defect of power supply components in outdoor pcb assembly • No ground connection in air conditioner unit (affected by noise in power source)
Communication Error
