Whirlpool awm5125 wont stop after wash cycle has finished. machine works fine everywhere else like filling, spinning and emptying it just doesnt stop once the cycle is finished, it starts filling up again and washing if you dont turn off at the plug,....
SOURCE: FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
SOURCE: whirlpool duet hf error
This error code indicates a water supply problem.
Are both the hot and cold water faucets turned on?
Turn on the water. Check the household faucets to see if the hot and cold water faucets are turned on. Completely open both faucets for proper fill.
NOTE: Both hot and cold water must be connected to the washer and turned on; the washer will not properly operate with only one incoming source of water.
Are the water inlet hoses kinked?
Straighten the water inlet hoses.
Are the water inlet valve screens on the washer clogged?
Turn off the water and remove inlet hoses from the inlet valves in the back of the washer. Inside the inlet valves are screens. Remove any accumulated film or particles from the screens. Reinstall hoses, turn on water, and check for leaks. See the Installation Instructions for details; find them by entering your model number in the search tool below.
Is the water pressure less than 10 psi?
If the water pressure is too low, the washer may not properly operate. To find out your exact pounds-per-square-inch (psi) value, contact your local water utility company.
Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds can prevent the washer from detecting the incoming water.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
See also: Why HE High Efficiency detergent is required.
Are you using flood-preventing inlet hoses that can shut off the water to the washer?
These hoses have a valve inside that will close if the water pressure is higher than two gallons per minute; this will shut off the water to the washer. If one of these hoses becomes loose, the water flow through the hose will increase and close the valve inside the hose, which will shut off water to the washer to prevent a possible leak or flood. If the hose is not loose, try taking the hoses back to the store for a replacement set.
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTES:
Hi paul johnson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Or else call me+971505221824
what details do you need? the machine is about 12 years old and is the AWM5215/5 version.
