With the power button on, the remote control suppose to be able to turn TV on/off. However there is a failure in the red standby and green power on mode which both lights up and resets the TV to standby mode.
SOURCE: When I push the power
I know these sets, did a lot of work on them when new and under extended warranty.
Two common problems:
With the back off look at the black transformer to the right with a big red wire that goes up to the bell of the picture tube: lots of these will arc at the top left side of the part--if you turn the set on and see a brief spark there the Flyback transformer is bad.
These are quite affordable and fairly easy to replace.
The second problem they have is there are about a dozen brown caps in front of the Flyback and one of them "opens" not a short but if it opens voltage etc go up and set shuts down.
8 out of ten times it is the Flyback.
Look closely at the white label on the left side of the flyback--the part number is there!
If this told you something you did not know rate this solution as very helpful as I do this here for free.
I have not seen many of these sets lately but still have the 3 new remotes my shop gave me.
SD TECH
My Loewe did the same thing tonight. The picture went blank and the rered and green light came on together. Any suggestions?
SOURCE: Remote no longer puts TV in standby
I found an original replacement remote for a Loewe ARC332PB at remotes.com
SOURCE: Our CAL232 TV will not turn on. When pressing the
Hello, My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is 1. the red light comes on 2.after about 1 second the green light turns on for about 12 seconds 3. the the green light turns off for about 1 second 4. then the green light turns on again for about 12 seconds and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button. Any thoughts?
On blu ray remote control hold down TV Power+01 at the
same time. If the TV turns off the controller is programmed. If not, try TV Power+02,
+03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
TV Repair Technician found the problem with the power supply, need to replace a $144 dollar circuit board.
