LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
A
Anonymous Posted on Jan 07, 2014
Thin blue vertical line on my Samsung LED ES7500 40", how to fix it?
3 Related Answers
omaharox
Mike
  • 166 Answers
  • Posted on Jan 20, 2010
SOURCE: i have a thin blue/green line running vertically
The plasma panel is going bad and is not repairable.
Anonymous
  • Posted on Feb 09, 2010
SOURCE: have red blue vertical lines on samsung lcd tv
Oh ok
Anonymous
  • 523 Answers
  • Posted on Jul 13, 2010
SOURCE: A thin blue vertical line has just appeared in
yes ss sent out a paper to us call for dervice there might be a wire loose
1helpful
I have a samsung UN60EH6003FXZC led tv, and I see a thin blue colour vertical line in the middle of the screen, which does not reach the bottom of the screen, any suggestion
Could be the Main board or T con ( if it has a seperate one) or more realistically the screen itself. Not a "home" solution and in all likelihood expensive.
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Each time I turn on the T.V. I get a thin solid blue vertical line down the center of the screen. Is this a common problem? What is the fix?
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
1helpful
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 • NEC LCD
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
