SOURCE: can a sony blu ray s350 accept movies with netflix
I just had a chat session with Sony and the BDP-350 Blu Ray can not stream video from Netflix or Amazon.
Julie_> Welcome to Sony Online Support. I'm Julie. Please allow me a moment to review your concern.
Julie_> Thanks for waiting, xxxx. I'll be glad to assist you with the information about the compatibility of the Blu-ray Player to stream the videos.
Julie_> I'm very sorry to inform you that the Blu-ray Player is not compatible to stream the videos from netflix.
Julie_> Only the BD-Live feature of the Blu-ray discs played in the Blu-ray Player can be streamed.
Julie_> At this point of time there are no Firmware updates available to make it compatible to stream the videos through Netflix. 12/2/2009
SOURCE: My Blu-ray keeps saying no disc.
This can be caused by a number of different things, some simple ones are:
- Unplug for 5 minutes then replug, this will reset the processor and it may smarten up (just like rebooting a computer)
- Take the unit apart and using a Q-tip and lens cleaner gently clean off the lens of the laser...only do this is you feel comfortable. If there is a hair or obstruction on the lens it will not read discs. If it is still under warranty, send it in first before you take it apart, it may void warranty.
- If the above two do not work then the transport mechanism may be defective and the repair would be around 100 -150 dollars, which is probably not worth repairing and it is best to look at a replacement machine.
Hope this helps!
SOURCE: unlock sony blu-ray bdp-s370 player
Turn on the BD player. Press and hold the PLAY button and the STOP button until UNLOCKED appears on the front panel display.
SOURCE: Will not play any disc that it use to play.
I had the same problem with mine and took a chance. it would read dvds but not blu-ray disc. i have done this procedure before with a regular dvd player so i tried it with my blu-ray and it worked. First you must open the blu-ray and take the blu-ray/dvd drive out open it up expose the lazer eye reader (make sure the blu-ray player is unpluged) and clean the eye with cotton swab diped in rubing alcohol.i would recommend using a flashlight when doing so. do this lightly and dry the eyes with the other side of the swab. you will see the difference once you clean it. I opened mine up after cleaning it with a dvd cleaner and the eye was still dirty. the eyes had a light film on it. I seen this on my dvd players that i have cleaned before. the film was enough to make the player not read the bul-ray disc. do not try this if you are not comfortable taking stuff apart and putting it back togetter. i hope this fixes your problem.
