Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In ______________________________________________________________________ •Headset Indicator Headset Status Red-----------------------------------------------Charging (battery level less than 50% charge) Yellow-------------------------------------------Charging (battery level more than 50% charge) Green--------------------------------------------Charging complete
---------------------------------------------------------------------- ====================================================================== ====================================================================== ====================================================================== ---------------------------------------------------------------------- With No Charger Plugged In __________________________
Headset Indicator Headset Status ______________________________________________________________________ Off ---------------------------------------------Power off Three blue flashes------------------------Powering on/off Steady blue --------------------------------Pairing/connect mode Rapid blue/purple flashes -------------Connection successful Quick blue flash --------------------------Incoming/outgoing call Slow blue pulse --------------------------Connected (on a call) Slow blue flash ---------------------------Standby (not on a call) Slow red flash ----------------------------Idle (not connected to phone) Slow purple pulse -----------------------Connected call muted Steady red ---------------------------------Attempting to connect Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on ----------------------------------------------------------------------
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
well it could be that you overcharged the batteries. You should not leave the scooter on the charger full time. you should charge the scooter nightly while you sleep unplug from the charger when you get up in the morning. the charger should not be on the scooter more than 12 hours per day and that rare. Whenever you have a red and green light on the charger the scooter is fully charged and can be unplugged. Always put it up fully charged and then charge after each use. Your batteries need to be replaced and charge the new ones before use then charge overnight each day that you use the scooter. If you don't use it for a few days you should still be fully charged than charge after use Hope this helps
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
Okay what happens sometimes is the charger gets into a feed back loop. What to do is remove the battery unplug the charger wait a few seconds (Maybe 20/30) plug the charger back into the outlet and then put the battery back in the charger. It should start to charge again and a few minutes later go to the blinking for full charge green.
It'll happen the other way as well meaning if the battery gets a memory (they say they don't but they do) you need to unplug the battery let is sit till it's cool and put it back on charge again. I've had this problem many times and have put it on charge and back off several times with in 15 minutes before it started to charge as it should.
Also these batteries do have a life span and if it's a three year old battery with many charges it could be failing meaning it just won't take a full charge.
Please remove the charger and take the battery out of the phone for one minute. Whilst the battery and charger are out press and hold the power button for 10 seconds to drain any residual power from the phone.
Replace the battery and charger and after a minute power up again.
If the issue is resolved or if it persists please do let me know.
Unplug the charger from the phone. Pull the battery and wait one minute. Reinstall the battery and then reconnect the charger to the phone. The phone may not start up if the battery is completely dead, but you should see the green light fade on and off. If this is happening, let it charge for an hour or so before attempting to power it on. Also, make sure you use the correct home charger. I have had charging issues when I previously used car chargers in this situation.
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
