When installing my nero 7 premium application from a disk it says Windows installer stopped working, fatal error occured
SOURCE: Unable to uninstall Nero-
Try reinstalling nero, use the complete option if there is one.
Then go to download.com and download a program called CCleaner (it is a great program for cleaning out internet history and un-used files safely)
You will see 4 tabs on the left 1. cleaner 2. registry 3.tools 4. options
First at the bottom from when it opens up you sre in default cleaner, analyze and when done run cleaner (note you will have to run cleaner twice probably).
second click registry then at bottom scan for issues, when done select fix selected issues (when the pop up appears select no you do not want to back up the registry) next pop up select fix selected issues.
Third select tools, find nero in the list of programs and remove using CCleaner's remove tool.
This should fix your problem.
SOURCE: Nero error code
First of all if you have the Nero 7 setup file, try installing it once and uninstall from control panel -> Add Remove Programs, after that try installing Nero 8, if this doesn't solve the problem you can proceed with Microsoft Windows Installer Cleanup Utility, download that from microsoft website, Install it and Run it, then select all the entries of Nero from the list you get and click on Remove. Then try to Install Nero 8, it should work fine.
SOURCE: Can't reinstall nero 8 essentials
sir richard the best thing you can do with this type of is go to an early state of your system like restore. If you can't get in go thru your F8 key on boot up. press F8 before you see the windows logo and it will take you into safe mode from there you select the top one ( safe mode) and there you go to your start button and than accessories than system tools and chose system restore.
Ok if all else does not work than you will have to use your system recovery disc that came with computer.
good luck.
name: Bush - Neron 2007
comp: Baghdad - Rome 2007
serial: KC89-1080-1964-MAXX-4006-3200-811M
or: 1C89-K0CA-1961-M2AX-4011-2XXA-M715
SOURCE: UN-Install Nero Burning rom 5.5 FREE Version (now out of date)
System restore did not work either. It's probably a cookie or something hiding somewhere. I'll try to see if symantec can erase it.
