Posted on May 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Office Jet 630 will not print
I only use my Office Jet 630 for faxing and copying only and not connected to my PC. The faxing works fine. When I try to copy (or print a fax report) it prints a blank page. (Well maybe a few unreadible very faint lines.) I have replaced the blank ink cartridge twice and cleaned the inside. Any ideas?
  • gnsinger May 25, 2009
    I don't connect the OfficeJet all-in-one to cmy computer. I use it only for faxing and copying.
venugopal durairajan
Level 3:
  • Master 464 Answers
  • Posted on May 25, 2009
Master
Level 3:
Answers
464
Questions
Helped
194075
Points
1702
Please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
How do I install connect fax and scanner to my computer
There are a minimum of 3 cords:
power
phone
computer (likely USB)
Power to the wall.
Phone to a phone line.
USB cable to the computer.
Computer should recognize the machine is there. Load software.
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
The HP Officejet 6500 will now only print color copies, the black copies do not print, the officejet does not recognize the request to scan copies, the officejet will send faxes and show a fax is being...
not ridiculous as the new printer costs less than replacement cartridges
check for ink in the black cartridge
check that the driver is still connected
check for compatibility with the pc
1helpful
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
HP Office Jet 7410 printer copies, fax are black
If you make a copy and it is black, either the ccd (reader is bad or the lamp is out) either is the end. Take it back to staples if you can.
Make sure you unplug it for about 1 hour and plug back in and try a copy.
How do I use my HP office jet v40
Install software from disk or download from HP site
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
How do I get faxes and copies to print from tray 2?
That is an advanced feature, genrally this is known as Automatic drawer eligibility. However, I am not sure this device offers this advanced feature. Look for options to select drawers for your diff functions in your users manual. Sorry best I can say...
2answers
k24674
ADMIN Andrew
ADMIN Andrew
