I need info on my Professional Series P95f+ 19
CRT
Type
19" (18.0" viewable), 90º deflection, PerfectFlat CRT
Dot Pitch
.25mm aperture grille at center, .27mm aperture grille at corners
Phosphor
RGB B22 medium-short persistence
Glass Surface
Tint: TM~43.5%, anti-reflection, anti-static with AR film
INPUT SIGNAL
Video
RGB analog (75 ohms, 0.7 Vp-p)
Sync
H/V separated (TTL), composite
Frequency
fh: 30~110kHz; fv: 50~160Hz
COMPATIBILITY
PC
VGA up to 2048x1536
Mac®*
Power Mac™ G3/G4 up to 1920x1440
CONNECTOR
Signal
15-pin mini D-sub
Power
3-pin plug (IEC320)
POWER
Voltage
AC 90-240VAC, 50-60Hz (+/-2)Hz
Consumption
97W (typ)
CONTROLS
Basic
Power, 1, down, up, 2, UltraBrite™ hot key
On View®
Contrast,
brightness, H. size, H. position, V. size, V. position, pincushion, pin
balance, trapezoid, parallelogram, rotation, degauss, moir reduction,
H. convergence, V. convergence, ViewMeter® language, ViewMatch® color,
data recall and zoom
VIDEO INPUT
Bandwidth
285MHz
MISCONVERGENCE
0.25mm (max) at center
0.35mm (max) at corners
DISPLAY AREA
Factory Setting
353mm x 265mm (V) (typ)
Maximum Scan
367mm x 275mm (V), dependent on signal timing used
OPERATING CONDITIONS
Temperature
32-104º F (0-40º C)
Humidity
5-95% (non-condensing)
DIMENSIONS
(WxHxD)
Physical
18.8" x 17.9" x 18.5"
480mm x 456mm x 470mm
WEIGHT
Net
51.7 lbs. (23.5 kgs.)
Gross
58.3 lbs. (26.5 kgs.)
WARRANTY
Three-year limited warranty on CRT, parts and labor.
REGULATIONS
UL/cUL, FCC-B, CB, CE, DHHS, ICES 003, ENERGY STAR®, NOM,
TUV/GS, TUV/Ergo, NEMKO, SEMKO, DEMKO, FEMKO, GOST-R,
SASO, PCBC, VCCI, BSMI, CCC, PSB, C-tick, Argentina-TUV/S,
TCO99 (P95f+B) TCO'03 (P95f+)
POWER MANAGEMENT
Meets TCO'99 (P95f+B),TCO'03 (P95f+)and ENERGY STAR standards
