Flatron m2362d
Hello
Researching your monitor specifications, it has a native resolution of 1920x1080 so the setting you are running should work.
Have you tried the other HDMI port on the monitor? It has to inputs and it is possible that the current port is causing the reported issue.
Another option is to get a DVI to HDMI adapter OR use a DVI cable with your graphics card to see if that corrects the issue. It is possible that the HDMI inputs are going bad and using a different input could resolve the issue. Both DVI and HDMI are digital inputs so you should not see any quality differences between the two connections.
The final check would be to connect your PC to another HDMI enabled screen (another monitor or TV) and see if the resetting continues on a different screen. If the problem occurs on a different display, you will likely have to download and install the latest video drivers for your card.
Hope this helps.
