Question about Sharp AR-5316 Advanced Digital Imager Copier
Reset service code sharp ar-153 - Sharp AR-5316 Advanced Digital Imager Copier
6ya staff
SOURCE:
Anonymous
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
Anonymous
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
Anonymous
  • 95 Answers
SOURCE: need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Posted on Mar 26, 2009
Anonymous
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
Everett Lin
  • 990 Answers
SOURCE: sharp AR-R550n
Hello sir; You may try to perform a reset procedure as follow;
press " program", " * ", " clear ", " * " and start key, then enter 17, press start again, turn machine off and back on.
Posted on Aug 23, 2009
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
I cant find the right driver for my sharp ar 153-E for my computer. thee system of my computer is windows 7
go thru the below link.
http://xpdrivers.com/printer/sharp/ar/ar-153e/_5_6731.cfm
May 23, 2011 | Computers & Internet
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Turn off developer led
HII.best way is that u have to replace developer with new one .new developer will reset it automatically.for to reset in this condition
press clear key ,exposure mode key,clear key,exposure mode key,
copier will go dead .press 24 then start 06 start
developer counter will bi reset
do not forget to rate the solution
MIAN AKHLAQ
Mar 17, 2009 | Sharp Office Equipment & Supplies
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
SHARP AR 651 SERVICE CALL
what is code nomber please send me
Jan 13, 2009 | Sharp AR-651 Copier
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
