Cannot get the paper tray back into the machine. What am I doing wrong? It feels as though it is stuck on something. Please help.
SOURCE: 6000 error on a Kyocera
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
SOURCE: Factory Defaults for Kyocera FS-1300D
Turn off the Dell printer (assuming you want to keep that IP address as is). From the computer/server the printers are networked to, go to Printers and Faxes and locate the printer. Right-click on the printer > Properties > and there should be a tab where you can change the IP address within...sorry I can't recall the exact steps from here as I don't have access to do so from my machine. Once you change the IP, reboot printer and your conflict should be resolved.
If all else failes, you'll need to consult the NIC card manual for further diorection.
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
SOURCE: I can't get a drive for laser printer kyocera fs
http://kyoceramita.com.au/fs720.asp has xp driver for fs-720
attach fs-720; windows 7 will recognise but fail to install
click on 'unspecified device fs-720' in devices and printers
click to upgrade/install driver
use driver specified above (xp)
should install properly
cheers
