Can the pop-up slide lock be replaced since the top of the catch broke
SOURCE: flash pops up, but flash closed warning stays
My E5700 did this a couple of times. The fix for my flash was that the unit wasn't actually popping all the way open. I closed it, then manually poppped open the flash and gave it a gentle upward tug. The flash seemed to lock into position -- and has worked fine since. I hope your fix is as simple as with my E5700.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
SOURCE: My Nikon D300 camera body broke into two, can the
probably...... but could be an ugly fix. epoxy strongest glue....but cna/superglue easier to use
