SOURCE: problem with washing machine
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
SOURCE: machine is locked with water inside
Are you getting an error code E20.because this would suggest a blockage in the pump/filter or drain.To get the water out there is a little hose down by the filter which pulls out a few inches and can be drained into a shallow dish,otherwise if you can get machine near the back door step undo the filter and let it drain outside,once drained get a torch and see if there is anything blocking the filter/pump.The end of the pump blade should be able to turn freely.Oh by the way once the water is out you should be able to open the door.Once you have done all before you put filter back in turn knob to spin or drain and you should see the pump spin.Now if all ok refit filter and check for leaks. Hope this was a help.
Good Luck.
SOURCE: I am in Spain and
Hi The issue seems to be with the timer going bad and should be
replaced. Hope this helps...please post back for further assistance. Daniel
