SOURCE: What is code for Olevia 42" TV, Product # 242-S11?
I have the Olevia 65 inch LCD TV and cannot find the comcast remote code for my TV! Any help?
SOURCE: I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
SOURCE: Model: OLEVIA 242-S11 HD picture does
Hello
You have to set the screen setup [Screen OSD Adjusting screen modes]. Get into Menu and come to "Changing the screen mode". In this mode you can adjust the screen settigs to suit your personal preferences.
Adjustment [For Analogue Soruce Only]
Adjusts the picture position and its quality.
From this window select "Aspect Ratio" optin.
Aspect ratio toggles the picture between 16:9 and 4:3.
If picture cuts from top and bottom, use Zoom function to zoom the picture and fill the entire screen. These fuctions can only active when you use analogue signal as input. When digital signal comes one, it will adjust with the transmission and it cannot be adjusted. OK.
