Microsoft Excel for PC Logo
A
Anonymous Posted on Jan 09, 2014
Delete name ranges - Microsoft Excel for PC
Scott
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Jul 17, 2014
Scott
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
9847
Points
46
It's a bit counter-intuitive...
Go Insert / Name / Define and the Define Name Dialog box will open & display the existing Range Names.
Select a Range Name to delete and hit the delete button.
Repeat as required.
Hit OK to finish.
Done.
2answers
My MacBook pro says that the epson printer is offline. but if I use my iPhone, it prints. please help
Try checking the ip address range on your MacBook. Apparently Mac Laptops tend to change their network ranges when they come in range of a new network. This means your printer is no longer in the MacBooks LAN address range. Also check and adjust your printers IP address and if necessary change it to DHCP or Auto addressing
How do u delete a name from messenger list? Do not want to block or unfriend just do not want names showing
just click on there name and it should let you delete.
that's right click on the name.
if not just high light the name and see if it will let you delete. go into your messenger list and try the above.
when you highlight the name and you right click on it,it might let you delete.
mind you if you do delete them they will be removed from your messenger..are you sure you want to do that because you are saying you just don't want to see there names.then you would want to hide there names.not delete.
How to shut off Bluetooth in my gmc Yukon
Using the
Delete
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Delete.
3. Say the name tag you want to
delete.
Using the
Delete All Name Tags
Command
This command deletes all stored
name tags in the Hands
Free
Calling Directory and the OnStar
Turn
by
Turn Destinations Directory,
if equipped.
To delete all name tags:
1. Press and hold
b
g
for
two seconds.
2. Say
Delete all name tags.
Listing Stored Numbers
The list command will list all stored
numbers and name tags.
Using the
List
Command
1. Press and hold
b
g
for
two seconds.
2. Say
Directory.
3. Say
Hands
Free Calling.
4. Say
List
3helpful
I want to delete my all my emails at one time
To delete multiple emails at once you can select a range by clicking on the check box next to the first message, hold Shift, and then select the check box next to the last message you want to delete.
After selecting the desired range, simply click the Delete button. The selected messages will be deleted.
Earlier it was printing ok but now it is not printing.
Yes you would create an on change event that runs a print and delete and select commands.
In vba of sheet1 enter this code change in code a4 and sheets (1) as necessary I tested and works so if problem its put in wrong place.
If you change it note I didn't insert an error handling script so you may need escape or control + break to stop loop. For instance if you don't delete the value thats to be greater then 0 every delete will create an on change event and loop.
Private Sub Worksheet_Change(ByVal Target As Range)
If Range("a4") > 0 Then
Sheets(1).PrintOut
Range("a4").Delete
Range("a4").Select
End If
8helpful
2answers
Weird folder/filenames that will not delete There is a folder on my WD 250 GB Passport Flash drive who's properties show it to be using 157 GB of memory. The Read Only attribute was set, unchecked it. I...
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
Solution:
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
I don't know how to port forward my comtrend adsl+
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "admin".
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
3answers
More than 256 characters in a cell in Excel
If a RANGES
\r\n
Named Ranges. SheetLevel Named Range, Named Constants, Named Formulas ,Relative Named Ranges ,Dynamic Named Ranges ,Advanced Dynamic Named Ranges .
\r\nWorking With Ranges. FindLast cell/row/column etc.
\r\nFormula Reference Changer. Absolute to Relative etc.
\r\nSpecialCells Method
\r\nExcel Named Range Manager $
\r\nOFFSET RANGES VBA
\r\nReturns a Range object that represents a range that?s offset from the specified range. Read-only.
\r\nexpression.Offset(RowOffset, ColumnOffset)
\r\n\\"expression\\" is required and should be a Range object.
\r\n
\r\nRowOffset: Optional Variant. The number of rows (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset downward, and negative values are offset upward. The default value is 0.
\r\n
\r\nColumnOffset: Optional Variant. The number of columns (positive, negative, or 0 (zero)) by which the range is to be offset. Positive values are offset to the right, and negative values are offset to the left. The default value is 0.
\r\n
\r\nExample
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(RowOffset:=-1, ColumnOffset:=2).Address
\r\nEnd Sub
\r\nIs the SAME as;
\r\nSub OffsetMe()
\r\n MsgBox Range(\\"B2\\").Offset(-1,2).Address
\r\nEnd Sub
\r\nOFFSET FORMULA
\r\nReturns a reference to a range that is a specified number of rows and columns from a cell or range of cells. The reference that is returned can be a single cell or a range of cells. You can specify the number of rows and the number of columns to be returned.Syntax = OFFSET(reference,rows,cols,height,width)
\r\n
\r\nExamples
\r\n=OFFSET(C3,2,3,1,1) Displays the value in cell F5.
\r\n=OFFSET(C3:E5,0,-3,3,3) Returns an error, because the reference is not valid.\", \"style=\\"background: #FFFFFF;padding: 2px;font-size: 10px;width: 550px;\\"\");" style="FONT-STYLE: italic" onmouseout="GAL_hidepopup();" href="http://www.ozgrid.com/forum/autolink.php?id=5&script=showthread&forumid=8">cell is formatted as Text, then it will display the #### when the text is over the limit. Reformat the cell to General and the text should again show.
Right click on the cell, click Format Cells, under the number tab, choose General.
Also, this ####, will occur is the cell width is to small.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
