Gentex 2010 Kia Rondo - All Rondo models - K2 Auto-Dimming Rear View Mirror Logo
A
Anonymous Posted on Jan 09, 2014
Wont go into park or reverse - Gentex 2010 Kia Rondo - All Rondo models - K2 Auto-Dimming Rear View Mirror
2003 chevy silverado wont go into park or reverse
The cable is not allowing it to go into these gears.more than likely a new cable is the resolution .
Ok my 2001 Grand Cherokee Laredo wont stay in park
Transmission sticks in reverse- won't go into park. - JeepsUnlimited
www.jeepsunlimited.com/forums/showthread.php?...won-t-go-into-park
Jun 14, 2013 - 12 posts - ‎5 authors 2003 6 cyl 4x4 Grand Cherokee Laredo automatic- Occaionally, when shifting from REVERSE TO PARK, my Jeep will stay in reverse. Typically its ... '2001 WJ'4,0L'42RE'NV 242'380000 km'ECE Compliant' ??????????? ??? ...
2001 jeep grand Cherokee laredo - CarGurus
www.cargurus.com > Questions > Jeep > Grand Cherokee
CarGurusJan 27, 2014 - 2001 jeep grand Cherokee laredo - Just purchased a 2001 Jeep GrandCherokee Laredo and ... It starts in PARK sometimes and sometimes it won't and I have to start it in Neutral. ... Hatch shuts flush, but won't stay shut. help!
2009 sonta wont go into park
the shifter wont move, or moves to park but park does not work?
try to be clear.
are you on flat ground?
are you against a curb
did you wiggle the steering and turn the key and wiggle the shifter to park? at once.
there is thing called park lock out but works moving from P/N to gears active, R/D/L. usually going to N/P is no problem. unless cables are rusty.
My 2000 ford explorer wont shift into correct gears and rolls when in park
your column eather shot or check your linkige from your column to tranney
My smart car wont go into reverse gear.
probably you need to reprogram the transmission
My 93 ford flareside wont shift to park or reverse
if it won't engage reverse the trans will need to be overhauled, the rev clutch has failed inside the trans.
1helpful
Chrysler concorde car wont shift from reverse to park
it sounds like your gearshift cable is broken..if you can jack up vehicle and support it safely,get someone to move shifter and look on driver's side of transmission and see if linkage is moving on trans..linkage is up near top of trans..i have seen this problem before
1helpful
2answers
Gear shift lever wont go into park; there's no problem with transmission or fluid vehicle works fine but i cannot get the shift lever to go into park, also i can remove the key while its in the reverse...
I have a Dodge Charger 06 model and the gear wont move from Park to reverse. everything else works as far as gas, brake light, etc but my gear wont shift can i get soem help
Transmission wont shift into park
need to adjust the shift linkage
Top Gentex Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Gentex Optic Expert? Answer questions, earn points and help others
