Healthrider 15.5 won't run,incline works fine,console lights up,beeps when buttons pushed,belt motor grunts and turns alittle won't shuts right off,led on control board is on constant no flashing,this machine has been stored for a yesr
Hi Geoff,
if it is contain belts please check.and try to move running belt it must run freely.sometimes it must stuck because of long idle time.
in electronic circuit the large smoothing capacitors can be damage because of long idling time too.
let us know the status,
regards.
nuwan
Testimonial: "the running belt moves fine,i took the drive belt off the motor and it's still the same"
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
SOURCE: My Healthrider 400se Treadmill slows down after 10seconds
Use only a single-outlet surge suppressor that is
UL 1449 listed as a transient voltage surge suppressor
(TVSS). The surge suppressor must have a
UL suppressed voltage rating of 400 volts or less
and a minimum surge dissipation of 450 joules.
The surge suppressor must be electrically rated
for 120 volts AC and 15 amps. There must be a
monitoring light on the surge suppressor to indicate
whether it is functioning properly. Failure to
use a properly functioning surge suppressor could
result in damage to the control system of the
treadmill. If the control system is damaged, the
walking belt may change speed or stop unexpectedly,
which may result in a fall and serious injury.
SOURCE: Healthrider S500i HRTL12990 belt won't run
HI,
If you can then before replacing the Motor control board do one thing. Replace the IGBT on the control board. Igbt is the component which drive the motor. It will not cost a lot. The only thing is you should be very careful while working on the motor control board because there you can see two capacitors which is capable of store charge for a long period of time even the treadmill is unplugged. Before doing work on the control board you have to discharge the capacitor. If not it will lead to serious electric shock. You will get many pages on web to know how to discharge an electrolytic capacitor. I have add the picture of the motor control board with the igbt marked. You can find the part number written in its frond side. Replace the IGBT first.
Ajin
SOURCE: My treadmill is locked in the max incline position and controls won't respond
Run the software calibration for diagnose, troubleshooting, and fix it.
2) clean the gear and shaft from elevation motor.
3) adjust the POT for better improvement.
see the diagram
God bless you
