SOURCE: C743 CAMERA SUTTER BUTTON
there are six screws (#0 phillips) on the sides and the bottom that you have to remove, two per side. Open the battery compartment and remove batteries and leave door open. the front should slip off, you might have to use a small flat screw driver to help the sides seperate. now there are three screws that hold the function button together. with the button out you can remove the old shutter button by GENTLY pushing the two little blue tabs to toward the center and into their little holes. be careful that the button doesn't shoot out and watch out for the spring. reassemble in the reverse order.
SOURCE: Which displays are compatible with the c743
Do not worry!
Kodak EasyShare C743 LCD display is on sale.
You can buy it from ebay.com with free shipping.
Open ebay.com. Write 250645463005 to the search box and press enter.
You will see the above item which is compatible for your camera.
Regards.
SOURCE: How to recover deleted picture from Internal
you can connect camera to computer and then try asoftech photo recovery program
http://www.asoftech.com/apr/
