I recently cleaned my Aficio 250 copier which had a spilled toner ink which did involved removing of components from the toner compartments. When I switch on the copier after cleaning, the message that came on the screen was "Please reset Photo-conductor" Please, do help me reset this conductor. Jerry.
SOURCE: ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
SOURCE: Error code sc 387 on my Ricoh Aficio 4006
Helo Joe!
Clean charge corona unit and around the drum. If your problem did't stop you must replace the drum potential sensor.
SOURCE: I had a Ricoh Aficio 2035 and i encountered
Clean the PCU unit components:OPC drum,cleaning blade,charge roller.
Clean in the developer unit the development roller,and the entrance seal plate.
Raise the toner bottle holder lever,push the lever to the side and then pull the toner bottle holder out and clean this unit to use a vacuum cleaner.
Clean the transfer belt cleaning blade and the rollers.
Testimonial: "ok, thanks for the help!"
SOURCE: Clean the drum on a Aficio copier
cleaning the drum wont help sounds like waste extraction coil is blocked
very very very common on those copiers and cleaning blade is contaminated,or you didnt keep it level when u moved it.In any case ull need engineer to fix it,unless u brave enough to take the drum unit apart and hoover all the toner/paper dust from the waste coil.Just dont touch any metal bits on your hoover ull get electric shock, have fun.
SOURCE: Ricoh Aficio 1018 printing lines, seems to be photoconductor
Cleaning the drum will not help. Depending on many factors including drum condition, number of pages printed etc, you will need at least to replace the drum cleaning blade. This is a common cause of black streaks. The drum should have been clean. The fact that it has toner on the surface is pretty good proof that the cleaning blade is bad. The part number for the blade is B0392289. I would do a search for this part and get one before you even think about trying to deal with the streaking problem. Once you get the blade, if you are mechanically inclined then replacing the blade is not difficult.
Good Luck and Thank You for using Fixya.
