Question about Mach Speed Trio Tablets & eReaders
Charge trio g2
Trio stealth g2 is new. Wont charge/power on. Just shows picture of a battery
    New Friend:
  • 170 Answers
Hi Jennifer,
Battery error or charger error.try with new charger or usb cable.
if you have warranty you have no problem and go for warranty.
regards.
nuwan
Posted on Jan 10, 2014
3 Suggested Answers
Anonymous
SOURCE:
eddie
  • 21 Answers
SOURCE: do i get into my tablet trio if i don't know the password or my gmail account
you can make another account and use that.you can have as many gmail accounts as you want
Posted on Mar 10, 2013
mrniceguyzer
zero popular
  • 4 Answers
SOURCE: Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Posted on Nov 28, 2013
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Trio stealth charging issues
The internal battery may be unable to recharge.
Jan 29, 2018 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
Trio stealth G2 Hype only gives me a battery picture and doesn't come on after charging
I've tied finding an answer. Nothing works. Get a new one, or if you still have a warranty, get it fixed
Sep 05, 2013 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth g2 won't turn on the battery drained last night so I put it on charge and in the morning I took it off and I pushed the power button and all it said was trio stealth g2 and it thats all...
there are several things u can try to reset it. but i have not seen many of reset and continue to work without having other problems. check out this link first.
http://youtu.be/jcreuqRxK6w
there is a reset on the back of the tablet..l use a paper clip and push the reset button and hold it until it turns off and then push the power and the sound buttons together ..sound button up. if this does
work use the power cord to charge it. if this fails return it with the link i use above..
good luck
chad man
Sep 01, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Trio stealth g2 just shows start up screen won't boot up
my table resets up on ever boot , you have to renter all the info every time you boot it up, Trio G2 10in
Aug 11, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Tablets & eReaders Logo
158 people viewed this question
Top Mach Speed Trio Tablets & eReaders Experts
Tom Chichester
Lawrence Oravetz
chomerly
Level 1 Expert
Are you a Mach Speed Trio Tablet and eReader Expert? Answer questions, earn points and help others
