Printer is connected to a Belkin N600 DB Router at the USB (USB connection between Router and Printer). Laptop is connected to the router by a wireless connection. Attempted many combinations to add the Printer on the laptop. At times, a print test page event occurs when is connection is made and stops. Printer Gateway IP address is known. Printer has a static IP address as well.
SOURCE: No wireless printer port for lexmark x4650
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
SOURCE: Connect Lexmark X5470 via wireless router
I would like to inform you that Lexmark X5470 is not a wireless printer. However, if you want it to use wireless then you should have a Lexmark N4050e 802.11g Wireless Print Server.
SOURCE: Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
SOURCE: wireless printer gets ip address different from my routers ip add
Is the wireless network on you router secured? a 169.254.x.x ip is an invalid ip meaning, it's not connected wirelessly to the router yet.
SOURCE: User's Guide does not contain software installation instructions.
I would recommend you to reinstall the driver from the below link. also if you click on Technical support - How to install downloaded driver it will show you how to install it.
-http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-X6570/catId=cat10004-category&prodId=4165-product;jsessionid=36351499255753845B8F3686DDD5E41C.node3
Also in the related links there's user guide for the Printer. it has instruction on how to configure network on your printer.
Please let me know if you have any further questions or concerns.
Thanks.
