SOURCE: Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
SOURCE: Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
SOURCE: maytag washer overflowing
Remove the tube from the water level switch. Blow it out so the sediment will stop blocking the tube. Re-attach it and pump out the water. Retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Maytag Washer PAVT-1 continues filling with water to overflowing
Does it still do this with power to the machine off? If so it is your water fill valve. Because no power is getting to the valve it has to shut off unless some foreign particles are holding it open. Remove and replace the water fill valve if still runs water after power is off.
Here are some things on how the selector switches work: If it stops when you remove power look at these possibilities.
Water fill switches usually have an air tube that as the water level
comes up the air pressure increases and causes the switch to go from
fill to wash.
I have seen rodents chew holes in the air tubing and this could be the cause or you may have a bad switch.
Some
times the switches also get out of calibration and need readjusting
(especially if you have moved in altitude like up a mountain or into a
valley).
If this helps you please rate me as high as possible.
If it doesnt help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
