Motorola Mobility SLVR L7 Cellular Phone Logo
Posted on May 26, 2009
Missing partitions on memory card
Memory card partitions are missing after scanning the phone with an antivirus. I think drivers are corrupt or missing
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
31
Points
Memory card not souport
5helpful
2answers
Photos on two separate memory cards are "read error" seems to be the pictures in the middle sections of the memory card. They won't show up either when tried to download onto computer. I...
you can try asoftech photo recovery software. You can see
http://www.asoftech.com/apr/
It tells the steps how to perform photo recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
19helpful
2answers
I want to scan my memory card ,i think there is a virus problem coz in memory card its shows filename.exe.if i want to remove thisat that time the file is removed but aftersome time,it again shows.I use...
Yo! i will advice you format the card rather than scan because you can only scan if you have antivirus on your phone which is not possible with many phones. so please format the card and you will get rid of it.
Aug 01, 2011 • Cell Phones
1helpful
3answers
My nokia 6120c cannot take picture, if you remove your memory card it works. and then i bought new memory card it works, and then my files in my memory card corrupted after putting it in a computer and...
The problem with your unit is the memory card. The memory card is either not formatted or continues to carry viruses from your PC. Try scanning your PC with an antivirus and formatting your memory card properly and also scan it for viruses. After doin this you can then put the memory card back and install a mobile antivirus on your device. Most likely Netqin antivirus. This should solve ur problems.
Hope this solution has been helpful?
2helpful
Nokia N70 Memory Card show Memory Card Corrupted in Phone And my coumputer.
If your memory card is showing memory card corrupted both on the phone and your computer, then it means there is a problem with the memory card. Most likely the memory card would have been corrupted by a virus.
What You will have to do is to try to run an anti virus scan on the memory card. To do so, when You connect the memory card to the phone, You will have to right click on the memory card, then select scan using the anti virus of Your choice. Then it will scan the memory card and wipe out all corrupted files and viruses.
After doing so You can format the memory card before using it again.
If it does not work, then it means the memory card is damaged beyond repairs.
Hope this helped.
Thank You for using FixYa.
2helpful
3answers
My Nokia E71 switch off by itself
Hello Zgoide,
May be the memory card of your phone contains the virus.
Scan the memory card using the any antivirus software.
It will solve your problem.
My nokia 3500c cant update music liabrary and reply music file not found.
This problem comes when you memory card is somehow got corrupted, what you can do is simply take out the memory card from the mobile phone and put in the separate external memory card reader, take the backup of your data from memory card, You will notice that the file size of the folders will be lesser than the memory used shown in the phone. This is because of temporary or corrupt files acquire the space of memory card
Again insert your memory card in the phone and Go to Menu>Gallery>Select Memory card>Options>Format memory card, it will format your memory card, switch reboot your phone,
Copy back the data of your memory card , and open music player now it will update your library automatically,
PS, you can take the backup of your memory card, by plugging your phone with the computer and select as Mass Storage Device, and you will be able to access your memory card as a Flash Drive, Run Antivirus scan also if there is any virus will be deleted automatically
PS. Always Keep the backup on external source for data safety
If you require more assistance, feel free to reply to this post
Thanks for contacting FixYA
Regards, BA
3helpful
My Nokia for e63, the memory card have been corrupted for many times whenever i used wap to download songs, games && etc. Please, i need ur help to release the virus from my handphone.
hi
put your memory card in the card reader and connect to the system.. then scan through the antivirus in your system.. this will erase all the virus i your memory card.
after scanning .. then back up the data and try to format the memory card .. then restore the data. and try it now in your phone . this will fix your problem..vote for this answer
thank you
2answers
I GOT VIRUSE IN MY PHONE HOW TO OVERCOME THAT
Remove the memory card and read in PC by connecting memory card with card reader.Then scan for virus.After scanning non of virus found in memory card restore your phone settings.
Thank you Fixya team
The screen is blank on my Nokia 5800, although the green white and red lights are on.
CHech ur memory card. there can be some viruses or some file corrupted, so scan ur memory card from an updated antivirus & then scan ur memory card by defragment option, it will get u on start/accessories/sytem tools / disk defragment...
after
Scanning & defragmenting insert ur memory card & start the phone.. it will work
S.kumar
3helpful
3answers
I think my nokia 5300 has a virus, i cant see my images or videos in my memory card
try to scan it in a computer
back up it and format after that you can now bring back ur backup
paste to your memory card
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
