Cooktops Logo
A
Anonymous Posted on Jan 09, 2014
Change ignition control module
All of a sudden...none of my igniters are clicking on my gas cooktop stove. What should I do?
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • KitchenAid Master 518 Answers
  • Posted on Jun 27, 2015
Marat Brikov
KitchenAid Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324479
Points
3123
changing everything on this kitchenaid cooktop video
5 Related Answers
Anonymous
  • Posted on Mar 29, 2008
SOURCE: Jenn-Air JGD8130 Gas Cooktop will not ignite
I just ordered one of these---sounds like people are not happy with this model---please get me more info
dcshelper
  • 7 Answers
  • Posted on May 28, 2009
SOURCE: replace dcs gas cooktop re-ignition module
donho1,
most likely the problem is the switch places onto the shaft of the valve. to replace the switch, you would need to remove the burner cap and port rings. you will see a large brass nut that needs to be removed on all 4 or 5 burners. next you would need to remove the nut in the center of the simmer port ring which is also the venturi for the main burner. you must be careful when removing this nut as they have a tendancy to lock onto the jet holder and could be hard to remove (don't strip or break the venturi or holder).....after you remove those nuts, the burners and top can be removed (watch the igniter wires). you can remove the switch by removing the retainer clip that holds the switch onto the valvestem.
Anonymous
  • Posted on Jul 25, 2009
SOURCE: gas cooktop - burner won't ignite
if its the burner that hase the intermitent timer on it
i have the same problem & I troubleshooted it.
if u take the cover off thier is a part on it that the rest dont have. its a red thing that rotates & thier are little contacts in it. for some reason thier is something that messed up inside it.
i took both mine apart & switced the guts & one of the little "boards"
is not working properly.
so im shure that is your problem
Anonymous
  • 1304 Answers
  • Posted on Oct 17, 2009
SOURCE: The igniter on the right front burner of my GE Gas Cooktop
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Anonymous
  • Posted on Jan 04, 2010
SOURCE: stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
How can i change the igniter module
take any loose grates off and raise the top like opening a car hood..it raises up on hinges..
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Igniter clicking
I have a stove that doesn't light (click) I've replaced the igniters, I've replaced the knobs, and I've replace the box all the igniters and plugged into. There's nothing else to change out and it still doesn't give a spark. I've got gas and electricity but nothing will light
Viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Igniters will not work
did the water fall on the spark module do you hear a faint click ,igniters dont go bad if they get wet if you say theres power going to the cooktop then you might have a bad spark module.
Top KitchenAid Cooktops Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
