Model # MLE2000AYW Serial # 35857558ZD Maytag Neptune Stack. Was wondering if this has a pump cleanout on it I had heard this could keep it from going into High Speed Spin if enough water is not out?
SOURCE: my Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
SOURCE: Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
SOURCE: neptune wont spin
Looks like I may have to post this as a solution to get the link to you. I never tried to put a link in a clarification request.
Click on this Forum. If that doesn’t work here is the link to paste in your browser.
http://www.fixya.com/support/p46844-maytag_neptune_mlg2000a_front_load
SOURCE: My Maytag neptune MAH8700A washer is not going
Clean out the drain filter located inside the bottom compartment.
SOURCE: My Maytag Neptune stackable model
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch.
In the stackable it is just behing the door lock.
Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color)
To be safe replacing both the things would solve your issue,
If you need furthur assistance, You can leave me comment, i may help you
RNJ VINOD KUMAR
